An error occurred while logging in - Connection error
I have had mango running for about 18 months, log in once a week or so and check the solar data it
records, and emails me. Last login, I updated, an now a week later, I realise i cannot log in.The login screen comes up, but fails with "An error occurred while logging in - Connection error"
System:
$ uname -a Linux mango 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1 (2020-01-20) x86_64 GNU/Linux
Java:
I noticed the java install advice has changed to openjdk, so I upgraded, but no luck.$ java --version openjdk 14 2020-03-17 OpenJDK Runtime Environment AdoptOpenJDK (build 14+36) OpenJDK 64-Bit Server VM AdoptOpenJDK (build 14+36, mixed mode, sharing)
mango:
ma.log only has INFO data logged
Starting Mango 3.7.5 with Schema Version: 29all the processes seem to be running OK
$ netstat -antp Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 454/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 422/cupsd tcp 0 196 192.168.220.80:22 192.168.220.103:56870 ESTABLISHED 610/sshd: robert [p tcp6 0 0 :::8080 :::* LISTEN 2125/java tcp6 0 0 :::22 :::* LISTEN 454/sshd tcp6 0 0 ::1:631 :::* LISTEN 422/cupsd tcp6 0 0 :::8443 :::* LISTEN 2125/java tcp6 0 0 :::5502 :::* LISTEN 2125/java tcp6 0 0 192.168.220.80:45056 192.168.220.75:502 ESTABLISHED 2125/java tcp6 0 0 192.168.220.80:5502 192.168.220.75:2902 ESTABLISHED 2125/java tcp6 0 0 192.168.220.80:43566 10.11.21.253:502 ESTABLISHED 2125/java tcp6 0 0 192.168.220.80:8443 192.168.220.103:53812 TIME_WAIT - tcp6 0 0 192.168.220.80:8443 192.168.220.103:53946 TIME_WAIT -
I think the two "TIME_WAIT" lines are my login attempt.
Where can I look for errors / logs that might help resolve the issue.
Hi All,
Well its the next morning here in Australia, and I am at home waiting for the corona virus to get me, so I clicked on the link for my mango install, and firefox did the security warning for a self signed certificate again - strange, then
then the login worked, and up came the screen.
Anyway, any thoughts on what magic happened overnight ?
Check your ma.logs, if this thing is internet facing someone may have been hammering it causing the login to drop out in relation to max non-authenticated attempts being tripped..
